Why is this sweep through 3d edges varying so much?
3 ANTWORTEN 3
Nachricht 1 von 4
gustavodelucaf
233 Aufrufe, 3 Antworten
Im creating a sweep using 3d edges in a circular and ascending directions, but Im having this issue where depending on the number of segments I pick, the profile is distorted from the center for some reason:
The orange was where I picked all the segments at once.
The blue one is where I picked each segment on its own.
The grey one was a mix of both.
Just needed to know why this happens, and how to make it a single profile, so the encounters are correct.
File attached,
Thanks!
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: gustavodelucaf
Edit Sweep and adjust the Horizontal Profile Offset.
Nachricht 3 von 4
Vertical Profile Offset as well.
Nachricht 4 von 4
TripleM-Dev.net
Hi @gustavodelucaf,
This happend because of the way the 3D edges were created te begin with
Each edge can have a different plane so depending the first picked, each sweep  can/will have a different origin, angle etc.
See @barthbradley reaction on how to adjust this.
- Michel
