I don't know if I'm missing something, I know with some RVT Link Collab Files there is some troubleshooting involved, though I am having a hard time mitigating a viewport issue on an interior elevation. When the elevation is dragged in it seems fine, then the viewport just becomes massive. Do you guys have a solution or a clarification for this?
Thanks!
There is probably some element at the far extent of the viewport. Active it, and click and drag over the far end to see what you find.
Got CAD? Turn off Imported Categories under the View's VGOs and see if that changes the extents. If it does, then you've found the culprit.
Click on "Crop Region Visible" in the properties. Then check the extents. Its pulling something out there, whether its a CAD import/link and mentioned above, or something else.
