WHY IS MY GLASS WINDOW NOT IN LINE W GRID AND EXTRUDED? steps for solution are much needed,thank youuu~
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
hwangt0412
584 Aufrufe, 9 Antworten
Tags (1)
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: hwangt0412
Are those Curtain Wall Panels?  Looks like it.  You can create curved glass with a basic wall type that is the thickness and material of the glass.
In other words, the Curtain Wall would be comprised of Mullion and EMPTY System Panels.  The gazing portion of the CW would be the Basic Wall Type.
Nachricht 3 von 10
hwangt0412
als Antwort auf: barthbradley
okay thank you for that~will look into it
Nachricht 4 von 10
Share the file.
Nachricht 5 von 10
hwangt0412
als Antwort auf: ToanDN
i've solved the problem,anyway thank you so much for your kindness~
Nachricht 6 von 10
Care the share how you solved it?
Nachricht 7 von 10
lim.wendy
Hi @hwangt0412,
Welcome to the Revit forum. Thanks for reaching out to the forum. I am glad that you were able to solve the issue you were having. Can you share the solution so that others can benefit from this?
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Nachricht 8 von 10
hwangt0412
sorry you mean share the steps? i think i just followed the steps from the first comment and get some help from my friend XD~
Nachricht 9 von 10
hwangt0412
if im not mistaken,i just deleted this old version curtain panel and redo it,and the glass just become aligned w the grid~
Nachricht 10 von 10
lim.wendy
Glad it works out for you, thanks for marking Brath's post as the "Solution," as it will help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Rails Summit
