Why is Exporting Walkthrough taking 8 hours?!!!
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
1502 Aufrufe, 4 Antworten
My work is exporting but it is taking literally 8 hours to do so. How do I quicken the exporting process with keeping the realistic appearance?
4 ANTWORTEN 4
Nachricht 2 von 5
Aryen_Jacobs
als Antwort auf: Anonymous
Best advice: dont use Revit to do this kind of work. The only option that would make it faster is cloud rendering but that isnt supported at this moment.
It wont get any faster. the only thing  you could do is lower quality/settings. but it will still take a long time.
Nachricht 3 von 5
als Antwort auf: Aryen_Jacobs
What do you recommend I do with the file? Export it in hidden line then
import it into another software to make it realistic? If so, what’s the
best software for that?--
Leslie Jones
Direct: (909)904-6884
E-mail: iAmLeslieElizabethJones@gmail.com
Vision II Reality, Inc.
Nachricht 4 von 5
Aryen_Jacobs
It depends on what you want to achieve. I stopped making walkthroughs because of the time issue. Personally i use panoramic renders i make with octane render and then stitch them together in a 'walkthrough' like this: https://wauben.com/VR/Bemelen/index.htm
But if you want a 'movie' Lumion could be a good program to make the walkthrough. But still might take a long time. https://lumion.com/
If  you want to walk arround in the model like a videogame you could use the autodesk viewer https://viewer.autodesk.com/designviews  or a Unity export. https://unity.com/products/unity-reflect (with unity you could also have support for something like a HTC Vive
Nachricht 5 von 5
This is exactly what I needed. Thank you.
