Why is elevation grayed put in conceptual mass?
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
447 Aufrufe, 8 Antworten
Does conceptual mass has no options to make elevation?
Also where are these things from architectural template?
Is there an option like drag line where you can specify from where you can see things in the elevation?
8 ANTWORTEN 8
Nachricht 2 von 9
aRcHiTeCt.JM
als Antwort auf: Anonymous
... of course you can reposition the view
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Nachricht 3 von 9
aRcHiTeCt.JM
.... yes elevations are greyed out
... instead you can use SECTIONS to get the same result
aRcHiTeCt.JM
REVIT EXPERT ELITE
Nachricht 4 von 9
Where are these things from architectural template?  You're in a FAMILY template (rft); not a PROJECT template (rte).
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/Revit-file-types.html
Nachricht 5 von 9
als Antwort auf: aRcHiTeCt.JM
Thanks,section is a good alternative but there is one problem.
I put a reference image in elevation,is there a way to make it appear in section also?
Nachricht 6 von 9
aRcHiTeCt.JM
.... do you mean in the project browser?
... if so... yes you can
... just pull it from sections to elevations
aRcHiTeCt.JM
REVIT EXPERT ELITE
Nachricht 7 von 9
http://help.autodesk.com/view/RVT/2018/ENU/?guid=GUID-42B144AA-ED59-4909-B483-BF61A165BC84
Nachricht 8 von 9
There is no elevation tool in the family environment (conceptual mass included) except for the built-in elevations.  Alternately you can use the section tool for it.
Nachricht 9 von 9
als Antwort auf: ToanDN
Section tool has it's own problem.For some reason reference line behind from where the section is cut are also showing up in the section.
