Why IFC model color differ from Revit?
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
nuwul
2814 Aufrufe, 9 Antworten
Hi.
While trying to export the model to IFC, some items in the IFC model does not show the same colour as the revit model.
In Revit, i only use default IFC setting.
Why this happen? I have provided 2 images for reference.
Please help
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: nuwul
Maybe export or import mapping? Hard to tell from a picture. Post the file.
Nachricht 3 von 10
nuwul
als Antwort auf: barthbradley
Hi @barthbradley,
I'm just using revit sample file. I've tried with the IFC option & set to standard & load to the default txt file, but still same.
What i did was exporting the model from revit to IFC, then import the IFC file in Revit.
Here is the exported IFC file for reference.
Nachricht 4 von 10
Nothing loaded, champ. Like to see yours though -- even if you're using OOTB sample files.
Nachricht 5 von 10
nuwul
Not sure why the attachment not loaded. well, i've put the file in the dropbox for your reference:
https://www.dropbox.com/s/g33rbn1nyl93lfh/rac_advanced_sample_project.ifc?dl=0
Nachricht 6 von 10
nuwul
does anyone have any idea about this????
Nachricht 7 von 10
IFC now Opened. What am I looking for?
Nachricht 8 von 10
nuwul
IFC can open but the color is different from Revit, as shown in my 1st post attachment
Nachricht 9 von 10
You exported a Mass to IFC.  It was probably hidden in view when you exported.  Hide that transparent purple "thing" in the view and your materials will look correct in the view.
...or just delete it.
...one more thing FWIW: IFC Export converts Revit Masses to Generic Models.  You can verify this by examining the Properties of that "transparent purple thing" before you turn it off or delete it.
Nachricht 10 von 10
BTW: @nuwul,  Solution credits are welcome.   Did that solve your problem though?  It should have.  If so, I really like those lil' green check marks,   Hint, hint.
