why i cant save my file
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
900 Aufrufe, 6 Antworten
Im using R2017, but i can save my file and  the file browser (folder, drive) doesnt load/work
i need to use the "escape" key to back the proyect and try again but without succesfull
Tags (1)
6 ANTWORTEN 6
Nachricht 2 von 7
Sahay_R
als Antwort auf: Anonymous
Is this a workshared file?
Have you been able to save at all - to any location?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 7
als Antwort auf: Sahay_R
its not a workshared file.
I cant save any file like project, template, or family, only i can export to autocad
Nachricht 4 von 7
Sahay_R
Can you do a SaveAs?
Rina Sahay
Nachricht 5 von 7
I can not save as
Apparently the file browser is loading (but I can not see it) and the menu and revit' ribbons are turned off instead.
Nachricht 6 von 7
dgorsman
This is sounding like a classic "dialog box off screen" problem.  Usual solution is this:
  • ALT + SPACEBAR (invokes the dialog menu for moving/resizing)
  • M (selects "move" from the menu)
  • any arrow key (causes dialog to pin to cursor)
  • click to position dialog
Give the process a try with your browser window, or another open application first so you know what to expect.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Nachricht 7 von 7
als Antwort auf: dgorsman
The file browser has was in the auxiliar display, because we have set the second display as primary and now we are working with just one, when i connect another monitor and change the primary display the file browser was there,
Now we'll be more carefull when if we change the primary display
thanks so much!
Regards
