Why I cant place a topography surface on a site plan that I've create it? I've create a site plan but now I'm not able to create a topography surface when trying place it's points.
I can think of a dozen explanations. Let's examine your file. Be easier than playing the guessing game.
Post your file. Do you know how? Attachment.
As barthbradley said, many reasons to guess from.. But I'd probably give a shot to either View Range Issue, or a Visibility Graphics issue, as those happens a lot with new users..
Check the visibility graphics (VG) or (VV) and search for Topography, turn it on if it was off..
Or check from the view properties settings (if you are in your siteplane view), search for view range, then edit, then make the cutplane above your highest topography point, and set bottom and depth to unlimited..
