Go to Architecture Tab > Set Work Plane and make sure it is set to the Level.
Thank you so much for replaying. But I still can not make it work. Could you tell me more?
Thank you again
What @ToanDN mentioned should work. If it's not working in your case, you can delete the view and create a new Ceiling Plan.
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
Thank you. open " Set" can see other ceiling panels, but it does not allow I create a new ceiling panel.
Thankyou
Sorry, I still do not understand. Could you show me a video?
Thank you so much
Thank you so much
Pick the Level of that Ceiling Plan view.
