why families don't open?
Message 1 of 11
nothing happens after clicking open. why?
Replies (10)
Message 2 of 11
ennujozlagam
where did you get your family? it could be in higher version of revit? or your family file is corrupted? or share you file here so we can check. thanks
Message 3 of 11
this is a sample file. families do not open
Message 4 of 11
Secttor
try to open them directly from Revit..
Revit MEP - Electrical Certified Professional
Revit MEP - Mechanical Certified Professional
Draftworks.wordpress.com
Message 5 of 11
from File> open> family is ok.
but from File> project, the families do not open
Message 6 of 11
Secttor
@Anonymous- make sure you have selected all supported files when opening models. opening families is restricted to rfa's. In my Revit 2021 everything is working like it should.
Message 7 of 11
Mohamed-Nassar
in Family creation screen choose family category, Down you can find Cut with Model or cut with Void,
this method let u cut in ur geometry not in linked geometry, i have tested this method before.
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
Message 8 of 11
RobDraw
File>Open - Allows the opening of any Revit file.
File>[Open]>Project - Allows the opening of project files only.
File>[Open]>Family - Allows the opening of family files only.
Rob
Message 9 of 11
hmunsell
the only thing placed in the Progetto1 file you uploaded are 4 walls. Walls are System Families (like Ceilings and Floors) and will not "Open" like a Loadable/Component family.
Howard Munsell
Message 10 of 11
the families are not displayed what should I do?
Message 11 of 11
hmunsell
ok, so i'm a little confused. What are you trying to do.
  • if your trying to EDIT a family follow the steps @RobDraw spelled out.
  • if your trying to load a family to use, use the Insert > Load Family option to load a family
    • then use the appropriate tool to place it or pick it from the Project Browser > Families category
    • once a family is placed, you can pick the family and you will get the Edit Family option in the Ribbon.
Howard Munsell
