Why door/window family doesn't fully cut on the curtain wall?
bh-khanh
Message 1 of 27
bh-khanh
Hello  experts!
I am trying to place a door/window family on the curtain wall. But it doesn't fully cut, it is haft cut only. I don't know the reason why?
I am an amateur in Revit, so I would like attached the my testing here. Please help me by directly  do on the attached.
Thank you very much!
BH Khanh
Replies (26)
Message 2 of 27
They want to be on a full panel.
Message 3 of 27
bh-khanh
Hi @Anonymous , I am using curtain wall because our work is insullated panel. It's a series connection between each other. Each piece W=900 mm. But we also use the door which has wide more than W900, so somtimes I cannot place it in a fully panel. Do you have any other idea for this matter?
BH Khanh
Message 4 of 27
You can remove parts of the curtain grids to form larger panels in places.  I have done that here.
Message 5 of 27
bh-khanh
Hi @Anonymous
Because our panel wide is W900, so I would like to keep the joint line at the under and above of window & door also. I cannot move curtain grids because it will change the panel wide.
Thank you very much for your time. Please help me another idea!
BH Khanh
Message 6 of 27
jacques
Are you looking to issue fabrication drawings for each individual panel? In that case, why not use generic models instead of curtainwall?
Message 7 of 27
Join the Basic Wall Panels at the Grid Line. Should fully cut both.
...unless of course you have a Mullion there.  Then it won't cut through both.
Message 8 of 27
Add a Rectangular Opening to cut the other wall panel.
Message 9 of 27
bh-khanh
 Hi @jacques
It need to use curtain wall instead of generic models, because I have to creat the wide dimension for each panels. Like bellowing attached. Using the generic model cannot creat a dim on the plan view like autoCAD.
Thank you very much for your time!
BH Khanh
Message 10 of 27
bh-khanh
Hi anh Toan
I thought as your idea yesterday. It takes so much time to revise when receive new informatioin from customer. I tried to make another family by using array generic models, but it does not like a basic wall family. I can place only straight walls.  Could you take a look at the attached? It's not good, so I think the curtain wall is more better.
Message 11 of 27
Huh??? What's this file have to do with Curtain Walls, Doors and Windows???
Message 12 of 27
bh-khanh
Hi @barthbradley
I just want to explain why I want to use the curtain wall for my work.
Message 13 of 27
@bh-khanh wrote:
Hi @barthbradley
You're welcome.
Message 14 of 27
afonsolmnsilva
Community Visitor
Community Visitor
Hello guys,
I was reading this post because I have the exact same issue.
Did you find a way to get through this problem of dois and windows not cutting more than one panel in curtain walls?
thank so much in advance for your help!
afonso
Message 15 of 27
bh-khanh
Hi @afonsolmnsilva
Actually until now I have no idea for this solution yet. We have been trying to change to use generic wall instead of curtain wall and using the way to split generic wall into parts instead of using curtain wall. it's perfect way with generic wall with part option.
Give it a try on it?
Message 16 of 27
azad.Nanva
use Void to cut wall
check the "Cut with void When Loaded:
use CUT for each panel:
Message 17 of 27
Afonso__Silva
Hello @azad.Nanva
Thanks for your reply.
I just inserted a void inside the window family (and i tried it also in a dorr family) (and i checked the box to cut when loaded). However, the void still does not cut the curtain wall when i load it in the revit file. It just cuts a single panel.
Can you help solve this issue? Maybe show me a video of your workaround / walkthrouht process please?
Message 18 of 27
Afonso__Silva
Hello
Message 19 of 27
azad.Nanva
Message 20 of 27
Afonso__Silva
Hi Guys,
Thank you for your time and video.
It actually does not work with simple cut geometry. With my curtain wall panels, i just did this simple process and it worked perfectly:
1. Create a void inside family.
2. Check box 'Cut when loaded'
3. Insert the window/door family in the curtain wall (between 2 panels or more)
4. It just cuts 1 single panel
5. Select 'Join Geometry' and pick the two panels. You will see that the void will now cut the 2 panels, however the 'join/curtain wall grid' line will disappear.
6. Dont worry, select Unjoin Geometry and select the two panels again. You will see now that the 'join/curtain wall grid' will appear again and the two panel will still be cuted in the geometry of the window/door you inserted.
