Why doesn't the leader of the window tags doesn't go 90 degrees to the text box?
noconnorG728Y
noconnorG728Y
See image. When I tagged the window, this what is happening, I then have to go to each tag and align them......
TIA
Accepted solutions (4)
The leader connects the center of the window geometry to the center of the tag bounding box. Make sure the tag family box is centered on the ref planes.
noconnorG728Y
Hi
I tried and tried without any luck. The lad who created it for our project spend hours trying to solve. No luck as well
azad.Nanva
It is better to draw accurately from the beginning so that your werk will be easier.
(view in My Videos)
noconnorG728Y
Ah you're an idiot Niall. it has been a while I worked in the family
Thank you
azad.Nanva
?? you should accept my answer as a solution not yours !! or @ToanDN
