Why Doesn’t My Revit 2018 Material Browser Dialogue Box open?
19 ANTWORTEN 19
GELÖST
Nachricht 1 von 20
1713 Aufrufe, 19 Antworten
Hello everyone,
Why doesn’t my Revit 2018.2 Material Browser Dialogue Box open?
It does opens in the 2017.2 version.
Already tried anything listed online and even installed the Windows 10 OS again. didn't help either :enttäuschtes_Gesicht: After installing Revit on a clean OS and still having the same problem, i’m starting to believe that the problem is not only in my Revit.
Anyone with a Soulution?
Thanks in advance!
PS
Already tried following links and some more:
https://forums.autodesk.com/t5/revit-architecture-forum/revit-2018-doesn-t-find-mapped-drives/m-p/74...
https://forums.autodesk.com/t5/revit-architecture-forum/revit-2018-no-material-browser/m-p/7465828#M...
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
19 ANTWORTEN 19
Nachricht 2 von 20
ennujozlagam
als Antwort auf: Anonymous
@Anonymous hello, you can follow this thread "Revit 2018 No material browser". thanks
Nachricht 3 von 20
als Antwort auf: ennujozlagam
Hallo ennujozlagamas you can see in my Post, i have already posted this link as one that doesn't have any solution. Thanks anway
Nachricht 4 von 20
Viveka_CD
Hi @Anonymous
Thanks for alerting me to this thread.
I'm sorry to hear that you are still facing issues.
1.Can you confirm if you have the latest updates for your Revit version?
2. Is Revit the only application running when this issue occurs?
Please send us your journal file to investigate further.
Nachricht 5 von 20
plamen.hristov
als Antwort auf: Viveka_CD
I have a Revit 2018.2 install that won't open the Materials dialog box. I already uninstalled, did a pretty good cleanup, fresh install and the issue remains.
Answering your questions Viveka
1. The computer is on:
18.2.0.51
20170927_1515(x64)
2018.2
2. And Revit is the only application running
Let us know if you have any suggestions please.
Nachricht 6 von 20
als Antwort auf: plamen.hristov
Install the nVidia GeForce driver version 353.62.  Do not install any other version.
http://www.nvidia.com/download/driverResults.aspx/87789/en-us
Nachricht 7 von 20
plamen.hristov
als Antwort auf: ToanDN
Thank you for the suggestion ToanDN!
I did see that solution. The problem is the card is AMD Radeon HD 8790M and Intel(R) HD Graphics 4600, not nVidia.
The other solution I came across was to wipe out the whole station.
https://forums.autodesk.com/t5/revit-architecture-forum/revit-2018-no-material-browser/td-p/7465828/...
I hope there is a better alternative
Nachricht 8 von 20
Find a AMD driver circa late 2015 and see if it works.  If it does then you can try newer versions until it breaks.  If it doesn't then I have no idea.
Nachricht 9 von 20
Nachricht 10 von 20
jair_gh
I have a weird theory but since you reinstalled the whole thing I am not so sure anymore...
Could it be you had previously plugged two monitors while working on Revit and your material browser is "lost" on the second monitor?
That's my best shot.
Nachricht 11 von 20
Viveka_CD
Hi @plamen.hristov
We have to investigate further by looking at your journal file. Let me know if you can share and I'll provide you a private folder if you'd prefer.
Nachricht 12 von 20
Viveka_CD
Hi @plamen.hristov
I just wanted to follow up here, any progress on this issue?
Were you able to resolve the issue? if there is something that worked for you please share it with the community.
If this issue still persists, then let me know the following:
  • Does this issue occur with a particular model?
  • The development team would still need a journal and your Revit file to test and compare results once we reproduce this issue.
  • We would be able to diagnose system information as well as Graphics related data to RAM utilization etc.
We are seeing a few patterns with Revit 2018.2, graphics cards and Windows10 updates.
If you have any concerns or questions at that point I am happy to find some more information for you.
Looking forward to hearing from you.
Nachricht 13 von 20
Greg_in_VA
How to use/turn on Material Browser in 2019? Very frustrating
Nachricht 14 von 20
als Antwort auf: Greg_in_VA
Did you by any chance look at post #6 and post #9 of this very thread?
Nachricht 15 von 20
Viveka_CD
Hi @Greg_in_VA
Were you able to check the driver as mentioned by @ToanDN in posts #6, #9
Please let us know if this works. I look forward to hearing from you.
Nachricht 16 von 20
Viveka_CD
Hi @plamen.hristov and @Greg_in_VA
Please let us know if you've checked your driver.
Windows makes some automatic changes even after turning off your PC, so please check this link on How to Disable Automatic Driver Downloads on Windows 10
Let us know if this helps resolve your issue. I look forward to your reply update.
Nachricht 17 von 20
plamen.hristov
In my case we determined that was caused by uninstalling the Materials libraries.
Nachricht 18 von 20
Viveka_CD
Hi @plamen.hristov
Great. Thanks for getting back.
Let us know if you run into issues in future.
Nachricht 19 von 20
Greg_in_VA
Looks like I need to replace my graphics card. Discovered the AMD FirePro V4900 isn't  recommended. Thanks for your support!
Nachricht 20 von 20
Viveka_CD
@Greg_in_VA
Let us know if replacing the graphics card helped resolve this issue.
Thanks for getting back!
