Why does my floor plan look like this?
4 ANTWORTEN 4
Nachricht 1 von 5
mattDCBLP
247 Aufrufe, 4 Antworten
I didn't alter anything within my model and suddenly these solid gray hatches are appearing within the view- anyone have any idea why this is happening? I've never seen this before. Picture attached.
4 ANTWORTEN 4
Nachricht 2 von 5
EATREVITPOOPCAD
als Antwort auf: mattDCBLP
Is there a chance you have shaded view enabled instead of hidden line?
The definition of insanity is doing the same thing over and over again and expecting different results
Nachricht 3 von 5
Looks like you activated a Sheet View.  Double-click outside of the View on the Sheet to deactivate.
Nachricht 4 von 5
RSomppi
Is anyone else working on the project with you?
Share all of the view settings for that view or share a portion of the model exhibiting what you see.
Nachricht 5 von 5
Corsten.Au
Hello
looks like PHASE issue, or you are editing a workset and all other workset turned grey.
or you linked certain revit file and elements from the link files are showing all grey.
try to apply new view template and it should resolved. but do learn the root cause.
cheers.
Corsten
Building Designer
