Why does drawing file does not linked in Revit
2 ANTWORTEN 2
Nachricht 1 von 3
RnD_PIS
173 Aufrufe, 2 Antworten
Do have any idea why its unable to link a AutoCAD file into Revit 2021 its resulting not responding.
The import CAD is possible in this case.
Thanks..
Beschriftungen (1)
2 ANTWORTEN 2
Nachricht 2 von 3
EATREVITPOOPCAD
als Antwort auf: RnD_PIS
in the AutoCAD DWG try this
run the PURGE command
run the AUDIT command
The definition of insanity is doing the same thing over and over again and expecting different results
Nachricht 3 von 3
Dunno. Post the DWG here and we'll test it on our end.
