i need to align the side if the wall opening without moving the other side, in the family file it acts correctly, but when loaded in the file it acts like shown in the video not as required
please help
the video and the family are attached
Gelöst! Gehe zur Lösung
Gelöst von Kimtaurus. Gehe zur Lösung
Remove this EQ dimentions, check this icon:
P.S. I have Revit 17.2 and can't open your family.
i need this dim. to keep the center line of the family in center
what do u suggest
I can't recreate your problem, it works fine for me.
Which Revit version do you have 2018 or 2018.2?
Every now and then Autodesk published update releases for Revit. It's for subscription only.
OKAY, i'll explain my problem again..
the family is for a simple wall opening, i need to make the right and left side of the opening floating to be aligned with an already prepared opening.
now the problem is when i align the left or right side, it never reached the wall, and also moves the other side, please watch the video
Check for Left Reference Plan "In Reference" - Center and "Defines Origin" checkbox.
For Center Reference Plan "In Reference" - Weak or Not a Reference and uncheck"Defines Origin".
unfortunately this didn't solve the problem also, but thanks for trying
i think it's a simple problem i may can't explain it well
i loaded your family, and i recorded this video
do u think the problem is in my revit app??
do u suggest to get the last update as this may solve the problem ?
