Why do some "custom" Key Strokes not Work?
TonyShapiro
TonyShapiro
Room Separator does not work when using "RS".   There are others that I do not have recorded.
zhengrong.fu
Hello, TonyShapiro!
Thank you for reporting this issue! I wonder you may have set the "RS" for more than one command.
You can find the Keyboard Shortcuts settings in: Options > User Interface > Keyboard Shortcuts > Customize.
Export the assignment as a XML file and search Shortcuts="RS". You can find out if it's also used by other commands.
Please let me know if it doesn't work.
Zhengrong
Zhengrong Fu
Product Owner
