Why do overriden elements do not show patches when phasing?
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
svalen
863 Aufrufe, 5 Antworten
In graphic overrides in the phase manager, whenever I set anything to be overridden, even if I set the pattern not
to be overridden, when I cut a wall in section, no patches show up, I just get the outer lifework of the wall.
Why is this?
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: svalen
Huh? Got pictures?
Nachricht 3 von 6
hmunsell
sounds like you may have a override applied to the wall already, maybe?
here is one of my favorite images.... print it out and hand it on your wall.....
Howard Munsell
Nachricht 4 von 6
svalen
als Antwort auf: barthbradley
This is my exiting wall
I want to have existing walls greyed out in section, so i set the wall to overriden, and in graphic filter set the cut
linework to grey and leave the pattern as no overide.
My wall end up looking like below, with no interior lines or patches showing....
Nachricht 5 von 6
hmunsell
remove the Material.... check the halftone box.
Howard Munsell
Nachricht 6 von 6
svalen
als Antwort auf: hmunsell
Thank you!
