why can'y I change on the window frame color in a standard revit window?
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
svalen
2487 Aufrufe, 3 Antworten
I'm trying to change my muntin/frame colors to black, but it ends up changing the trim color too?
3 ANTWORTEN 3
Nachricht 2 von 4
hmunsell
als Antwort auf: svalen
I assume you have a material made that is the color you want? what window family is that? i have a "standard Revit window" loaded in my model and it only has 2 material options.
Howard Munsell
Nachricht 3 von 4
My guess would be that the muntin, frame and trim are sharing the same (or wrong) material parameter.
Nachricht 4 von 4
syman2000
Looks like your window is set to exterior frame material.
To make the mutin as different material, you may want to create new parameter.
