Why can't see tools in mass in place
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
900 Aufrufe, 9 Antworten
When I tried to use mass in place the tools för the mass editor not shown.(See the photo)
Why?
9 ANTWORTEN 9
Nachricht 2 von 10
L.Maas
als Antwort auf: Anonymous
Have checked the "Create" tab?
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 10
als Antwort auf: L.Maas
Thank u for answering. It looks like that when I clicked on the in-place mass and giva a name to my mass. I can't click anywhere only on finish or cancel mass. The bar shown beside is not the massing bar and when I cancel I come back till this bar not to massing.
Se the photo
Nachricht 4 von 10
L.Maas
You are not able to click on the create tab to switch over to there?
While most buttons are grayed out  I can click on the create tab to reach the massing tools.
So if you can not switch over to the create tab something else is going on.
-Some other (new) windows open?
-Try to restart your computer and and start with a new project to see if that solves it.
-Might be that an add-in is obstructing the tools. See if you can uninstall some/all of the add-ins and see if that solves the issue.
Louis
Nachricht 5 von 10
I tried to uninstall all the adds in and apps then it works. Then i reinstall one by one and I found that when i install Autodesk.RevitExtensions.Revit or an app that called Naviate the problem will be back. I take everything from the computer and install it again but this didn't help. This problem is not exist for my 5 colleages who use the same apps as me.
Nachricht 6 von 10
L.Maas
So at least you can get it to work when not using some of the add-ins, that is good.
It basically looks like OOTB Revit is not the issue.
You could try to contact the maker of one of the add-ins and see if they can help you with what the issue might be.
If the same works for you colleagues I also would start to look at other things. What are the differences between your computer and those of your colleagues?
-Check versions (Revit, and the add-ins).
-Different Operating system (e.g. win 8 vs win 10)? Look for updates for your system.
-Graphics card? Try to switch of hardware acceleration in Revit (under options). LAso look for other (older or newer) drivers.
-Check other programs that might interfere (e.g firewall, virus scanner).
Louis
Nachricht 7 von 10
Rafal.Gaweda
If it is related to Naviate please contact Symetri.
Rafal Gaweda
Nachricht 8 von 10
RDAOU
@Anonymous Hi
I would bet the Revit version you are using...if it's 2017.2 but the following is worth a try:
Have all add-ins installed back again and when it behaves like that again; Minimize Revit and then maximize/restore it again and see if ribbon goes back to normal.
Some add-ins seem to have been behaving weirdly with 2017.2 (ribbon locks/disappears/doesn't update/tabs concealed)....You might wanna try to reset the ribbon after the addins are installed...u do that by renaming the UIState.dat (while Revit is closed) file located in the following folder to UIState.old then start Revit and try if it works
%APPDATA%\Autodesk\Revit\Autodesk Revit 2017\ENU
(ENU for English - check the one for the language u use)
Nachricht 9 von 10
als Antwort auf: RDAOU
Hi, I changed the uistate.dat name and It is solved now. Thank you very much.
Nachricht 10 von 10
RDAOU
@Anonymous You are welcome :leicht_lächelndes_Gesicht:
@L.Maas @Rafal.Gaweda sorry for jumping in without excusing
