why can't Revit add roof fascia to a side of roof with curve?
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
tiho
1268 Aufrufe, 11 Antworten
This seems rather simple, yet Revit is refusing to add a fascia to a side of the roof that is not a sraight line and is an arc instead. Any comments?
11 ANTWORTEN 11
Nachricht 2 von 12
RyanCameron
als Antwort auf: tiho
In Revit 2023 at the moment and I did get it to work. Is your fascia more complex than a rectangle?  Sometimes it'll struggle with even semi-complex profiles.
RB Cameron, AIA, LEED AP, EDAC
Digital Practice Leader
Nachricht 3 von 12
Are you sure the actual roof edge is visible in the view? Not clipped by crop boundary or section box?
Nachricht 4 von 12
tiho
als Antwort auf: RyanCameron
Not complex at all. Really, just a rectangle. I'll try it in 2023. The model I'm working on is in 2022.
Nachricht 5 von 12
tiho
als Antwort auf: barthbradley
not clipped. I also tried it separately on another roof I created just to test the command and see if there was something wrong with the other model.
Nachricht 6 von 12
tiho
So I just tried it in 2023. It works if the roof is flat and has no slope. If I add slope to one of the lines, then it refuses to create the fascia.
Nachricht 7 von 12
tiho
Nachricht 8 von 12
Is it a Roof by Extrusion using a Spline?
Nachricht 9 von 12
@tiho wrote:
I can't either. Use a different approach. 3D Beam or another Roof or an In-Place Sweep.
Nachricht 10 von 12
tiho
thank you. So, its not me, it's the software!
Nachricht 11 von 12
KarenLBR
Hello.
Am I right in understanding this thread - Revit 2023 (full version) can't create a fascia on a curved roof plan? On this basis, I presume it's safe to work on the basis that Revit Light won't either.
Thanks.
Nachricht 12 von 12
Base12
Having a similar issue. (v2023.1)  The roof element is flat, and the fascia will click to the portions that are arcs, but the weird spline curve (which is EXACTLY how the client wants it!! lol) won't take the fascia.  It takes the click, but the segment isn't placed/doesn't appear.  The entire roof object was line-picked from imported .dwg geometry.  The only way I could get it to work was to recreate the spline by using a series of arcs.
