Why can't I use Top & Base Constraints option in Stacked Walls ?
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
ansaryashiq
412 Aufrufe, 4 Antworten
While using Stacked Walls in Revit either 2021 or 2022 . All the options are available to edit except Top & Base Constraints. If there is option provided but Can't able to access( Grayed out ) means What's the use of that option ?
Tags (2)
Beschriftungen (3)
4 ANTWORTEN 4
Nachricht 2 von 5
jay_colcombe
als Antwort auf: ansaryashiq
This is simply because you have not set any unlocked layers in the Base Wall Family used in the Stacked Wall.
You need to edit the Wall used in the Stacked Family and use Modify to unlock the Top Bottom Constraints for it to be available in the Stacked Wall.
Jay Colcombe
Autodesk Certified Instructor
Nachricht 3 von 5
Alfredo_Medina
Those "Top" and "Base" columns in the dialog box are not the same concept as "Top and Base constraints" as you said. Those values show the relation between two walls at the point where they join. You can create vertical offsets in between walls. Once you enter values, some other values become not editable. For example:
Nachricht 4 von 5
ansaryashiq
als Antwort auf: jay_colcombe
Thank you my query cleared now
Nachricht 5 von 5
ansaryashiq
als Antwort auf: Alfredo_Medina
Thank you my query cleared now!
