Why can't I place a door in a curtain wall?
9 ANTWORTEN 9
Nachricht 1 von 10
5083 Aufrufe, 9 Antworten
9 ANTWORTEN 9
Nachricht 2 von 10
constantin.stroescu
als Antwort auf: Anonymous
The Door has to be a Curtain Wall Door not simple Door.
Select a Curtain Wall Panel ( using TAB) and then insert the Curtain Door Family
Constantin Stroescu
Nachricht 3 von 10
constantin.stroescu
the best is to place the Curtain Wall Door , in an Elevation view facing the Curtain Wall, or (as in my screencast) in a 3d View...
Constantin Stroescu
Nachricht 4 von 10
als Antwort auf: constantin.stroescu
From the Insert tab, when I load the curtain wall doors, they do not appear under the door types.
Why is this?
Nachricht 5 von 10
In the Project Browser, they do show up under Doors.  When you are using the Door Tool though, only doors that are wall hosted are shown.
When you select a panel in the curtain wall, you will see panels, walls and curtain wall doors.   Notice what I said there?  You can change panels to walls too, that way you can still host a regular door into a curtain wall.  Not the greatest of methods, but if you wanted a framed door in a curtain wall that is a method you can use.
Nachricht 6 von 10
loboarch
In a curtain wall you are not "placing a door", you are "swapping a panel".
http://help.autodesk.com/view/RVT/2017/ENU/?guid=GUID-4B806EBE-2B46-4889-BC12-77FA23BFBA88
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Nachricht 7 von 10
You are so right this is way harder than it needs to be. Even when selecting the curtain wall, it does not let you create a curtain wall door or storefront door of any type. They are under families menu under properties loaded, however it does not let you create instance.
Nachricht 8 von 10
Yien_Chao
try this workaround : change the glass panel that will host the door to a wall that looks alike the panel. then you can insert the door.
Nachricht 9 von 10
You need to select a panel, not the curtain wall.  Use the Tab button to cycle through until you select a panel.  Swap it for a CW door panel.
Nachricht 10 von 10
martijn_pater
You are able to place a regular door family on a wall, so you could unpin a panel and replace it with a generic wall to which you could add your door family. This is probably not best curtain wall practise though, see reply Tim to use a CW door panel.
