Why can't I attach a lighting pendant family to the ceiling in Revit?
idpalina_adrian
idpalina_adrian
arq_42
Could you post the family so we can check it?
It may not be set up correctly to search for ceilings/work planes.
It could be that the ceiling isn't visible due to the range of views.
It could be that there isn't a ceiling.
¿Te resultó útil esta publicación? Dale "Me gusta".
¿Tu pregunta fue respondida correctamente? Haz clic en "ACEPTAR SOLUCIÓN".
RDAOU
@idpalina_adrian
It is a ceiling based family...ie: it needs a ceiling element in that view for you to be able to place it
  • Make sure you are on a ceiling plan
  • Make sure you have placed a ceiling element
  • Make sure that the ceiling element (ie: the host) is visibile in the view
You may also place the fixture in 3D view if that makes your life any easier, then align them in a ceiling plan
idpalina_adrian
Thank you so much for the clear explanation sir!  I was finally able to place the lighting fixture properly thanks to your detailed steps.
