Hi All,
Why can I see the wall from the linked model (Cyan) through my modeled wall (Gray)?
I want the linked wall below the modeled wall in the host model.
Underlay the linked model will not work for me since I want to see the discrepancy between both models; if I select the underlay option, the linked model will not show the wall's surface
Hi @cmiyares.mcsal,
Does the wall of the linked model have a graphics override (ViewFilter), I think that with a override it becomes on top of non-overridden elements, especially with solids.
Try a different override (backcolor and not forecolor) or also override the Gray walls?
I assume it's the Cut appearance?
- Michel
