Why can I not add a "mark" to certain walls?
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
svalente9GJKH
331 Aufrufe, 2 Antworten
I need to add a mark to a wood wall with wood siding but it is greyed out and I'm not able to add this?
Why might this be?
2 ANTWORTEN 2
Nachricht 2 von 3
RDAOU
als Antwort auf: svalente9GJKH
@svalente9GJKH
Is it a basic wall? if yes, it could be because it is in a linked model. In such case
  1. Either open the linked model and add the Mark therein
  2. OR copy monitor the wall to your model and Mark that one
PS: In the future, If you would add a screenshot it would make it easier to understand what is happening at your end
Nachricht 3 von 3
RDAOU
@svalente9GJKH
To wrap this one up based on other posts/questions you posted...System Stacked Walls does not offer the option to add Mark or Type mark. To add a Mark to the stacked wall components:
  1. Select Stacked wall
  2. Right click >> Break Up
Components of the Stacked Wall assembly can then receive individual Mark or Type Mark
