Why can' I change the name of a schedule while a view template is applied to it?
10 ANTWORTEN 10
GELÖST
Nachricht 1 von 11
cjpmurray
2128 Aufrufe, 10 Antworten
I have created a view template to schedule each of the partitions in the project. However, I have noticed that if I want to change the name of the schedule (as shown below) I have to take off the template in order to change the name.
I have more or less than 20 schedules for my partitions, and I'm wondering why this isn't similar to a instance parameter or something like that. Because everytime I adjust the name and take off the template I end up having to move all columns that I have moved to fit on the sheet. It has become very annoying having to do this every time I have to make a name adjustment.
Please if anyone knows any workarounds or if I am missing something i am open to listening.
10 ANTWORTEN 10
Nachricht 2 von 11
als Antwort auf: cjpmurray
I can change the View Name without turning off the View Template.
Nachricht 3 von 11
cjpmurray
als Antwort auf: barthbradley
I can change the view name too but that's not what i'm asking. It's the header in the schedule as shown here.
Nachricht 4 von 11
Not following you. That header is the View Name.  What am I missing?
Nachricht 5 von 11
Edit the Template and clear the Formatting box then you can re-title as you want.
Nachricht 6 von 11
cjpmurray
The view name does not change the header. It only changes what you see on the Project Browser in Schedules. See image.
Nachricht 7 von 11
cjpmurray
als Antwort auf: ToanDN
Yeah I guess that works, but would like it where I wouldn't have to mess with the template like that. Im just going to have to re align all my schedules then. I hope that no one wants to change the font or text, because that would be a real pain having to do that manually for all the schedules.
Nachricht 8 von 11
After rename you can recheck the formatting box and the column widths any other formatting will be back to match the template.
Nachricht 9 von 11
So, you do NOT want the Header Title to match the View Name and name in the Project Browser?
Nachricht 10 von 11
cjpmurray
Yes, the header has more information that i don't need on the Project Browser
Nachricht 11 von 11
cjpmurray
I don't have column widths applied because it varies every wall partition, and have to manually change the widths to keep it all info on one line. I think i'll try turning off the formatting and if becomes an issue then i'll just go back to what i have been doing. Just wish the header was something you could edit without having to turn off and turn on something
