why can I apply a color/material to my roof membrane but not my walls membrane?
1 ANTWORT 1
Nachricht 1 von 2
svalente9GJKH
230 Aufrufe, 1 Antwort
only difference is on my walls I applied the membrane to the plywood which is outside the core boundary rather
than my roof plywood which is inside the core boundary?   is this the reason I can't get my membrane color/material to show on my walls? Thanks
1 ANTWORT 1
Nachricht 2 von 2
Corsten.Au
als Antwort auf: svalente9GJKH
Membrane  ( in wall or roof ) are exception to the Function of those families.
Membrane can be of " 0 " thickness..
Note : Non-membrane layers should have thickness not less than 0.8mm
1. Structure
2. Substrate
3. Thermal / Air layer
4. Finish 1
5 Finish 2
Membrane - can be zero
Corsten
Building Designer
