Why are these columns sticking out of walls ?
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
490 Aufrufe, 1 Antwort
Normality an architectural column automatically join to the walls but sometimes it just doesn't blend with the wall and sticks out.
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: Anonymous
Sounds like the wall faces aren't on the same plane as the column. Go to Plan View and use Align tool to line 'em up.
...also, it doesn't look like they are joined at all.  Use Join Geometry tool.   Also, fool around with Switch Join Order.
