This is a wall I have used before I an identical template, but now the corners form like this.
It is a stacked wall - 10" foundation with footing. Mitre join does not work, pulling away and rejoining the
walls does not work either.
Any ideas how I can fix these walls?
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Click one wall, do you see a T symbol or an L symbol?
Worst case, disallow join, stretch them to overlap, join geometry manually.
When you place a wall, look on the Options Bar and you'll see the default Join Status. Allow or Disallow. Yours is likely set to Disallow. Change it to Allow and that status will remain the default until you change it again.
if what ToanDN and Barthbradley said doesnt work dubbel check your height since its a stacked wall a third option can be sthe diffrent walls in the model is not aligned at all if they have diffrent heights but most likely it is what ToanDN and Barthbradley said the joints.
