I'm making a curtain wall by making a form, creating a line, extruding it, subdividing, then using my own family for the panels. After the curtain wall is created, each individual panel's properties are read-only and cannot be set. I need to set these to give panels different depths. How can I do this?
So far, I've managed to get them to be editable within a conceptual mass which I can, in theory, insert into the project. However, in an rvt file, they are readonly ![]()
see if this helps. thanks
