Why am I unable to adjust relative base height on a spot grade?
2 ANTWORTEN 2
Nachricht 1 von 3
svalente9GJKH
176 Aufrufe, 2 Antworten
My relative base height option is greyed out/not able to be edited when I click on a spot grade.
Why might this be?
Thank you
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: svalente9GJKH
A spot grade?  Do you mean a spot elevation or a spot coordinate?
Nachricht 3 von 3
Create a TYPE that uses Relative Elevation Base. Then that one will give you the Option to pick Ref. Level.
