Why a basic functionality like importing PDFs, isn't part of the Revit LT suit???
2 ANTWORTEN 2
Nachricht 1 von 3
leeUT3Y6
199 Aufrufe, 2 Antworten
Revit LT should be a light program for architects. With all the functionality needed for working architects.
The only functionality which should be left out is construction and MEP related features.
Is there any Architect who doesn't use PDF for his work???
In Autocad LT you have all the functionality needed, why in Revit it should be different?
2 ANTWORTEN 2
Nachricht 2 von 3
mauricio_mssf
als Antwort auf: leeUT3Y6
Hi @leeUT3Y6 Just sharing what I know, don't be mad at me, I'm also a user trying to help another user.
The function Insert a PDF option is not included with Revit LT. as you can see
Cannot insert a PDF into model in Revit LT | Revit LT | Autodesk Knowledge Network
You can try convert thes pdf as a .dwg file in AutoCad and import, or try like this guy and save as a image.
(1) Import pdf in Revit LT - YouTube
compare yourself
Revit vs Revit LT | Compare Revit Products | Autodesk
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Nachricht 3 von 3
RobDraw
And why exactly should architects get full functionality?
Do you know that it is a newer function that was not available to anyone not very long ago?
Your opinion is better suited for the IDEAS forum or Product Feedback. This is a user help forum.
Rob
