who can explain to me what exactly does Lock option?
bms953
bms953
when i want create a grid, i choose Pick line tools and then i can active Lock check box, but i don't know how this work,
please explain for me with example
Behzad Meskini
Competitor in World skills Competition 2005 Finland (Mech,Eng,CADD)
Member of Iranian Elite Foundation
Autodesk Certified Professional-AutoCAD
Autodesk Certified Professional-Inventor Pro
Autodesk Certified Professional-3ds Max
Autodesk Certified Professional-Revit Architecture
Autodesk Certified Professional-Revit Structure
Autodesk Certified Professional-Revit MEP
DS CATIA Certified V5 Mechanical Surface Designer Specialist
DS CATIA Certified V5 Associate - Part Design
DS CATIA Certified V5 Associate - Surface Design
DS Solidworks-CSWP-Mechanical Design Professional
DS Solidworks-CSWA-Advanced Sheet Metal Professional
DS Solidworks-CSWA-Advanced Weldments Professional
DS Solidworks-CSWA-Advanced Surface Professional
DS Solidworks-CSWA-Advanced Drawing Professional
Alfredo_Medina
The Lock check box next to the Offset text box, when using "pick lines" is available when the offset value is zero. It means that you can pick a line as a reference and have the element aligned and locked at the same time, without you having to do align & lock in two separate steps.
In the illustration provided, there is a wall. I want to create a grid line that is aligned and locked to the center line of the wall. Then I use Home > Grid > pick lines > offset = 0.0 > activate "Lock" > pick the center line of the wall. The result is that the new grid line is both aligned and locked in one single step to the centerline of the wall.
bms953
tnx, unbelievable , it's very simple but i can't use this, i got it
Behzad Meskini
