Hi there!!
I have been using Revit for past 4 months, and find it quite difficult to make complex free flow/ organic forms in it. Would 3ds max be helpful in such cases?
What if Heydar Aliyev Center, Baku was to be modeled, could it be done with either of the two?
thanks
Hello @Anonymous
The best software for modeling and render is 3d max ..
(Rhino) also good for free form but if you pro using max it will be enough ,you also can combine between programs 3d max accept any model from any program
I would say Rhino 3D would give you the best bang for the buck, especially when you combine it with Grasshopper.
If you have money to burn then look into Digital Project. But sounds like it only servers a niche market, either due to cost, or its closed platform nature, or both.
