Which settings do I use to make vertical mullions a continuous rhythm between two joined curtain walls?
jwakeleyUE75A
jwakeleyUE75A
I am using a curtain wall to represent wood slats. Here I have two curtain walls made by using a mass face. I want the rhythm to continue across these two planes. Any suggestions? I run into this problem frequently and can't seem to ever get a handle on it. Photo above for condition in question.
SteveKStafford
For wood slats pattern you might consider using a railing of just balusters. That would distribute your vertical slats across the whole path. With the curtain wall you'd need to exclude the beginning mullion of the second curtain wall and let the last mullion of the first curtain wall stand in for that "shared" relationship's position.
Steve Stafford
jwakeleyUE75A
Thank you for this! I will give it a go and report back.
mari.shimode
Hi @jwakeleyUE75A, did you have a chance to try the solution provided yet? If it helps to solve your question, please use Accept Solution so that others may find this in the future. Thank you!
Mari Shimode
