which is the best file format to import in order to get fine objects without meshes
1 ANTWORT 1
Nachricht 1 von 2
2835 Aufrufe, 1 Antwort
Hello, We have available 3d models of formats such as 3dm, 3ds, DWG, IGS, STP files. Which one of these is the best to import and get as 2d without more unnecessary lines. Dwg , 3dm can be directly imported in Revit and can be used in project file. But, assist me to do further like this with various format.Please suggest any if you come across this.
1 ANTWORT 1
Nachricht 2 von 2
elzohry2007
als Antwort auf: Anonymous
save DWG to sat
then
SAT File
Fusion
From Fusion
To Revit using
see this
https://www.youtube.com/watch?v=ZxBb34TXhew&ab_channel=KaramBaki
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Hosam Elzohry , ACI , ACP, Autodesk Ambassador Gold
BIM Manager
https://www.youracclaim.com/users/hosam-elzohry/badges
Dynamo
using Synthensis toolkit
