Good day,
Currently I am trying to do energy analysis using Revit Architecture. I have to define which HVAC system is used in the residential building. In Revit the HVAC systems are given as follows by default:
1) 2-Pipe Fan Coil System, Chiller 5.96 COP, Boilers 84.5 eff
2) 4-Pipe Fan Coil System, Chiller 5.96 COP, Boilers 84.5 eff
3) 11 EER Packaged VAV, 84.5% boiler heating
4) 12 SEER/0.9 AFUE Split/Packaged Gas, 5-11 Ton
5) 12 SEER/7.7 HSPF Split Packaged Heat Pump
6) 12 SEER/8.3 HSPF Packaged Terminal Heat Pump (PTHP)
7) Central VAV, Electric Resistance Heat, Chiller 5.96 COP
Central VAV, HW Heat, Chiller 5.96 COP, Boilers 84.5 eff (default)
9) Residential 14 SEER/0.9 AFUE Split/Packaged Gas <5.5 ton
10) Residential 14 SEER/8.3 HSPF Split/Packaged Heat Pump
11) Residential 17 SEER/9.6 HSPF Split HP <5.5 ton
12) Underflow Air Distribution
But the building I investigate uses Chinese-made air conditioners, which have their own energy efficiency rating EER 2.79/COP 3.35. I would like to know which HVAC system given by default is the most similar to necessary air-conditioner with EER 2.79/COP 3.35?
Or how can I convert Chinese energy efficiency rating into American/European one? As far as I uderstand energy efficiency ratings given by BIM are used in Western countries.
