Which element would suit best as a decorative, non-strucural "support"?
3 ANTWORTEN 3
Nachricht 1 von 4
dariawerynska
231 Aufrufe, 3 Antworten
Hi fellows!
I have modelled an auditorium and I wonder if it's possible and purposeful to include some more decorative elements in Revit or you would advise to model it in some other 3D software.
Below I attach my idea for the auditorium. I want to model these green lines as wooden panels. Recently I modelled fancy stairs using a command "roof by extrusion" and now I'm wonder if there is some other smart way to model the idea from the drawing.
What to you think?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: dariawerynska
Yes you can use Revit tool to create those: architectural columns, non structural beams, etc...
Nachricht 3 von 4
aRcHiTeCt.JM
... hi @dariawerynska
.... you can create anything you want
.... take a look at these frames and elements (attached .rvt)
... you can model entire families in any material
.... if you need help just ask me... I love to do that
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Nachricht 4 von 4
I would build them in the model just as you want them built in the field, and  I would use loadable components, just as @ToanDN suggested.
