Where To find Reference Plane Instance and Remove
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
15197 Aufrufe, 4 Antworten
I am trying to reduce a bloated project model built by a fellow staff member in Revit 2017.
Using Ideate Explorer, I have identified over 950 "Reference Plane Instances".
I can't single them out, I can't find them anywhere, Revit can't "Show Me" where they are. I can get their ID number by Revit can't find them anywhere.
Even when Ideate Explorer selects them I can't delete them.
What the heck are they and how do I get rid of them?
4 ANTWORTEN 4
Nachricht 2 von 5
constantin.stroescu
als Antwort auf: Anonymous
Doesn't it work ,if you select all and then apply Filter?
Constantin Stroescu
Nachricht 3 von 5
Alfredo_Medina
As I have commented before, this should be written in the project's BIM standards: important reference planes should have a name and should be in a dedicated workset. Any reference plane that does not comply with this should be deleted. This is just bad practice, to fill a project with a thousand reference planes without any classification. I assume you can find them with select all in project, but that is not going to tell you which planes are important and which are not.
Nachricht 4 von 5
Can Ideate Explorer distinguish between reference planes placed in the model versus placed in in-place families versus place in loadable families?
Nachricht 5 von 5
MacurFZGVK
als Antwort auf: Alfredo_Medina
Select all option is not working for reference planes, it is grayed out.
I guess the only option is to try with dynamo.
