Where is Room seperator?
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
svalente9GJKH
506 Aufrufe, 4 Antworten
This is a simple one....but I can't find the room separator tool.  Use to be in the architecture tab,  but i don't see it
and all tabs are maximized...
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: svalente9GJKH
Where's your Room and Area Panel?  That's where the Room Separation Lines are.
...did you drag it somewhere?
Nachricht 3 von 5
If you can't find it, maybe a reset will help.
https://knowledge.autodesk.com/support/revit/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-r...
BTW: are you using dual Monitors? It could be on the second Monitor - even if it's turned off.  .
Nachricht 4 von 5
svalente9GJKH
this worked.  wonder why this happened?
Nachricht 5 von 5
You probably did it inadvertently. I have before.  It's easy to do.
