Where does Revit gets its conductivity values for materials?
4 ANTWORTEN 4
Nachricht 1 von 5
asli.kayaCWZ8G
359 Aufrufe, 4 Antworten
Hi everyone! I was just wondering where Autodesk gets their default material properties such as conductivity, if it is taken from a referenced document. I need to do a double check with the values I have but I cannot be sure which one to use, so a reference would be great.
Thank you so much!
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: asli.kayaCWZ8G
This?  Probably some ASTM.
Nachricht 3 von 5
You want to double check Autodesk values?  What are you double-checking?  Whether or not they differ from some other specs you have?  If you have specs, then don't use a built-in Thermal Asset. Use your own.
Out of curiosity, how are you using Conductivity downstream?  In Energy Analysis using Detailed Elements?
Nachricht 4 von 5
asli.kayaCWZ8G
als Antwort auf: barthbradley
I am actually doing a thermodynamical analysis of a vertical farm through EnergyPlus, by downloading the energy model`s .idf file from Green Building Studio. I have some international standards for me to look at material properties and they are not that different. I just wanted to reference the values in my research paper if they are derived from a source by Autodesk because it is a detailed model, but could not find any information related to it.
Nachricht 5 von 5
By "detailed model" do you mean the Energy Model is created using Detailed Elements (under Advance Energy Settings)?  Reason I ask is because I don't think material conductivity of a material used in a System Family Assembly is going to be of much value.  I mean for instance, if a Model is using a Basic Wall Type to represent a 1-hr. Stud Wall, the Stud Material would not fill the entire core of the Assembly.   In reality, the Studs would be offset from each (i.e. 16" on center).  Know what I mean?  Maybe Schematic Types is better. Dunno. Just throwing it out there for what it's worth.
Anyways, why don't you post on the Insight Forum. This stuff is in their wheel-house.  I think you'll get further there than here.
FWIW:
https://download.autodesk.com/us/revit_mep_2016/constructions-revised.pdf
