I currently have both Revit 2022 and 2023 installed. I cannot for the life of me find the default UniformatClassifications.txt file. New projects based on the Imperial-Architectural template indicate the file should be at C:\ProgramData\Autodesk\RVT 2023\Templates\English-Imperial\UniformatClassifications.txt but there is no such file, and the Assembly Code Settings dialog shows a yellow warning triangle at the File Location field.
Where do I find this file? Is my Revit install somehow incomplete?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
C:\ProgramData\Autodesk\RVT 2022\Libraries\English-Imperial\UniformatClassifications.txt
Looks like you did not install any content. Do it.
Revit 2022:
Revit 2023: go to your Autodesk Account page and install content
From here?
Does the Autodesk Desktop App not give you an option to install this content, or did I just miss it?
Edit: To clarify, I use the Autodesk Desktop App to, well, install my Autodesk apps. I don't remember seeing an option to install "content" using this method.
Edit 2: I see it now in my Autodesk account. Huh. I haven't been in here for ages. I should probably poke around.
@JADAstudio wrote:
From here?
Correct. You need to install content separately since at least several versions already.
Awesome. Thanks.
Strange that there is no link to the content installers from Autodesk Desktop App (unless I'm blind). If you have to manually go to your account to get the content anyway, why give users the ability to install via ADA?
¯\_(ツ)_/¯
