Where can I get a copy of Revit 2014?
2 ANTWORTEN 2
Nachricht 1 von 3
652 Aufrufe, 2 Antworten
I am in a class which is using Revit 2014.
I had Revit 2014 educational version installed at home. Last weekend, I reformatted my hard drive, and now the only versions available for download are 2015, 2016, & 2017.
Where can I obtain an educational copy of 2014?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Autodesk only list three latest versions for download so 2014 has been gone when 2017 came out last year.  Hint: if you want to keep 2015 then download it now before 2018 shows up in a few weeks.
Why do you need to stick with 2014?  If it is for training then just get a newer version instead.
Nachricht 3 von 3
Darin.Green
@Anonymous
You can download the 2014 version from the Autodesk Virtual Agent
Here's a directory download link:
Autodesk Revit 2014
If this information was helpful, please consider using the Accept Solution
