I really do have to ask when will we get one. Its been 2 months now since I wrote the autodesk support when we will get a update for the 2022 IFC Exporter. Having to keep one old 2022 Revit version on a different PC is contraproductive as it might cause bugs working on a single cloudmodell. (Yes im aware of the Github links but its again for the older Revit version not for the 2022 - 22.1.10.541)
Do we have any ETA or something?
@poehm wrote:I really do have to ask when will we get one. Its been 2 months now since I wrote the autodesk support when we will get a update for the 2022 IFC Exporter. Having to keep one old 2022 Revit version on a different PC is contraproductive as it might cause bugs working on a single cloudmodell. (Yes im aware of the Github links but its again for the older Revit version not for the 2022 - 22.1.10.541)
The 2022 version has been out for a couple of month now (22.2 and 22.3) and the latest version on Github for Revit 2022 which I am currently using since a week or so is IFC R22.4
I have not yet received the update past 22.1 so Im still stuck on that version. And the github version does not work for that one. The moment I click on export IFC Revit crashes and thats that.
This is the only available update for me and either the updates are rolled out in waves or it differs in countries.
I was referring to the exporter not to Revit hotfix ... I am using the IFC Exporter release 22.4 with Revit 2022.1 and it seems to work so far
https://github.com/Autodesk/revit-ifc/releases/tag/IFC_v22.4.0.0
If the Above is giving you issues try the previous version which was also working on 2022 https://github.com/Autodesk/revit-ifc/releases/tag/IFC_v22.3.0.0
Which version of the Exporter do you have installed? Maybe if you uninstall any older versions and reinstall
I was not aware of the 22.4 version I did a clean installation of the 22.4 but the issue is the same. For clarification here is a video what exactly happens.
There are no error messages anywhere not in the system. Are there any Log files I can check / post here or something?
Edit: @RDAOU Tried the 22.3 version as well same issue as shown in the video. I tested the 22.4 version on 10 PCs with the same Revit version as we update them all and it happens there as well. Either this is one of those unlucky moments that all 10 PCs have corrupted Revit files which I highly doubt because the probability is too low for that or something isnt right with the exporter?
Edit 2 : Ofc I tried it on different Revit files as well with the same outcome.
