When Revit puts the door, the gap does not open
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
turhanabdulkadir
455 Aufrufe, 7 Antworten
When I add the door in revit 20 or 10 door drawings, the door comes but the gap does not appear. Everything is in place in 3D
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: turhanabdulkadir
Lower the View Range Cut Plane so that it intersects with Door.
Nachricht 3 von 8
jay_colcombe
As @barthbradley states this would typically due to the Cut Plane in that View.
You can check this in the Properties Palette > View Range > Edit
In this example this is a Standard OOTD View with a Cut Plane Offset
This example is where it is placed above the Door
Jay Colcombe
Autodesk Certified Instructor
Nachricht 4 von 8
handjonathan
Hi @turhanabdulkadir
Thanks a lot for posting your question to the forums!   Has the solutions suggested by @barthbradley @jay_colcombe helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
Nachricht 5 von 8
You might also be seeing the Door that way because you are view in the "wrong" View.  Maybe you're in a Ceiling Plan View - not Plan View.
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-58711292-AB78-4C8F-BAA1-0855DDB518BF
Nachricht 6 von 8
turhanabdulkadir
als Antwort auf: barthbradley
Thank you very much for your interest, but I have looked at each floor level unfortunately I am on the correct floor plan.
Moreover, I am not the only one with this problem. We are also looking for a form with similar problems
Nachricht 7 von 8
turhanabdulkadir
als Antwort auf: handjonathan
Nachricht 8 von 8
turhanabdulkadir
als Antwort auf: jay_colcombe
It was solved from the view range. You guys are great. Thank you very much.
