When resizing the window, the glass becomes untransparent
6 ANTWORTEN 6
Nachricht 1 von 7
678 Aufrufe, 6 Antworten
In Revit 2020, when loading a family of windows that usually work in other versions, when you resize the glass, it turns gray. What could be the problem? Thank you.
6 ANTWORTEN 6
Nachricht 2 von 7
L.Maas
als Antwort auf: Anonymous
Depends on how the family is made. Can you upload the family so we canhave a look?
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 7
Well that's bazaar. Post the Family.
Nachricht 4 von 7
als Antwort auf: L.Maas
Sorry, I forgot to attach the family.
Nachricht 5 von 7
If "Стекло" = Glass, then I may have found the issue.  The nested Family's "Стекло" Parameter needs to be associated to the Parent Family's "Стекло" Parameter.
In fact, all the nested Family parameters should be associated to Parent Parameters.
Nachricht 6 von 7
als Antwort auf: barthbradley
Thank you so much for your help!
Nachricht 7 von 7
noah_conlayFAWXC
It is hard to believe that Revit still does not have a way to control the Interior Elevation boundary crop lineweight/thickness.
Dear Autodesk, Could you please engineer a way to adjust the lineweights of all interior elevation crop regions?
