When placing a room, other levels populate my plan view
7 ANTWORTEN 7
GELÖST
Nachricht 1 von 8
cherylellington
886 Aufrufe, 7 Antworten
When I try to add a room on this level (6), the whole level turns blue and reference lines from other levels appear, blocking out the layout of my level 6 so I can't see to place rooms on 6.
7 ANTWORTEN 7
Nachricht 2 von 8
in VGO> Model Categories>Rooms- expand and uncheck Interior Fill and Reference
Constantin Stroescu
Nachricht 3 von 8
in a Section View activate Room visibility and check the Upper Limit not to exceed the Level in which the Room is placed...(Level 2 in my screenshot )
Constantin Stroescu
Nachricht 4 von 8
Thanks Constantin--When I'm in section and look at room visibility, the upper limit of whatever room I check reflects the level the room is on, yet the room in section expands beyond that.  In this case, when I look at a room on level 4, the upper limit is set to level 4, yet the room spans 62'  (4 floors), which is what the limit offset says.  I have no idea why the limit offset says 62' for that room.  Each of my rooms exists on one level (13'), yet they show a limit offset in properties of 62'.  If I change the limit offset to 13', the room on section reduces to the correct, single floor.  Not that's the way to handle this?
Nachricht 5 von 8
Constreit to upper Level with a Limit Offset of 0.00
...or , use Volume Computation setting to Areas and Volumes to adjust Rooms to Floors..
Constantin Stroescu
Nachricht 6 von 8
hmunsell
als Antwort auf: cherylellington
Do you have Links in your model?
Do you have rooms placed in different Phases?
Howard Munsell
Nachricht 7 von 8
Ok--working on this now--seems good so far--will let you know when through!
Nachricht 8 von 8
cherylellington
als Antwort auf: hmunsell
Thanks Howard--no links or phases--think it's been the limit offsets....
