When inserting the structural column as depth, it is not showing
2 ANTWORTEN 2
Nachricht 1 von 3
074bce107.pramod
358 Aufrufe, 2 Antworten
while inserting the structural column as depth, it didn't show my column? help me please
message shows like this;None of the created elements are visible in Floor Plan: B View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings.
2 ANTWORTEN 2
Nachricht 2 von 3
Lachlan-JWP
als Antwort auf: 074bce107.pramod
The column is below the view range for that particular view. Open a 3D view or a plan for the level below and the column should be there.
Nachricht 3 von 3
ennujozlagam
instead of depth, select height. thanks
