When I try to create risers using the sketch tool it only counts the first one.
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
bourgaud.jimmy
3204 Aufrufe, 4 Antworten
Hello
When I try to create risers using the sketch tool it only counts the first one so I can't create my stairs... Does someone knows how to fix this please ?
4 ANTWORTEN 4
Nachricht 2 von 5
Avaris.
als Antwort auf: bourgaud.jimmy
That vertical green boundary at the left side needs to be a riser too. Boundary is only left and right side of the stairs, not top and bottom.
Nachricht 3 von 5
bourgaud.jimmy
als Antwort auf: Avaris.
Thanks !
This brings another question though... Is it possible to add risers that starts on the same point ?
Nachricht 4 von 5
Avaris.
I do not understand, could you sketch it or show a reference?
Nachricht 5 von 5
bourgaud.jimmy
It's been solved thank you for your help :leicht_lächelndes_Gesicht:
